What're these connectors?
Old May 19, 2004 | 11:36 PM
cargasm66's Avatar
Car: 89 RS
Engine: 305 TBI
I was under the hood today and I noticed 2 connectors unplugged, and I am not positive where they go. Any ideas?
They are located directly behind the belt tensioner, and go into the bottom side of the black smog pump thingy.
Thanks!
~Chris
Old May 20, 2004 | 12:15 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
ac?
Old May 20, 2004 | 12:26 AM
cargasm66's Avatar
Car: 89 RS
Engine: 305 TBI
I didn't think my car CAME with A/C. Could you buy a camaro from the dealer without the AC? That's the impression I was under...
Old May 20, 2004 | 12:49 AM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Looks a little like your car may have came from the dealer with A/C in the past (unless you bought it new without it) and someone removed it. The big pulley on that side where the connector is is where the A/C compressor should be, and is the optional A/C delete pulley. That would be some connector for some sensor that hooks into one of the A/C lines, just like the one I disconnected today.
Old May 20, 2004 | 10:41 AM
IronbackTA's Avatar
Car: 86 Aero TA
Engine: ZZ4
Transmission: T-56 Rear: Dana 44
I would have to go with A/C wiring also. From the pic it looks like you have a standard (non A/C) heater box. You car probably was ordered without it. GM just put the full wiring harnesses in cars to save time and money. When I switched from a 700 to T56, I found the clutch switch wiring taped up under dash by the pedal area.
Old May 20, 2004 | 11:09 AM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
Yep. A/C Low Pressure Switch connector.
Old May 20, 2004 | 11:11 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
The round one is the a/c pressure switch that would normally plug into the rear of the a/c compressor and the other is for the compressor clutch.
91 SrS
Oct 7, 2015 04:32 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
meeklay812
Oct 1, 2015 03:46 PM
tmork454
Sep 29, 2015 06:33 PM
Gordonr1973
Sep 29, 2015 11:59 AM
