test for alternator charging
Old May 22, 2004 | 11:00 PM
kammi10's Avatar
Car: 1989 camaro
if i got the car running and nothing else on would the car still run if i unhooked the battery so the alternator was doing all thr work?
Old May 22, 2004 | 11:55 PM
AM Racer's Avatar
It should, but I wouldn't do it.
The surge from the loss of the battery could damage the alternator and a lot of electronics.
Also, you've got 3 different posts for the same problem rephrased.
Old May 23, 2004 | 03:16 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
The best way to test alternator output short of checking amp output is to turn on as many loads as possible and check voltage. It should be higher than 12.5 volts.
Hotrodboba400
Dec 10, 2019 07:07 PM
Johnoooooo
Sep 22, 2015 08:55 AM
J.C. Denton
Sep 21, 2015 04:23 PM
sahlomonic
Sep 20, 2015 07:15 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
