Dash Harness, must be replaced
Old Jun 7, 2004 | 05:29 PM
Joez88Camaro's Avatar
Car: 1988 Camaro Sport Coupe Convertible
Engine: Your Momma
Transmission: I can go forwards and backwards
Let's put it this way, looking at it, it seems my car has had 3 different alarms installed, poorly. Then when I replaced my carpet I saw so many random wires in the center console it was scary. I actually tested a few and I found one was to my dash lights, however the fuse to it is getting no power whatsoever, but if a run a switch between that wire and one of the 20 amp connections they work fine. I have problems with my blinkers, lighter, everything in the dash. So, I feel it is necessary to replace that harness. Camaro heaven sells complete ones, however, I need diagrams and lists of the connectors to see what really needs to be done. BTW, the firewall ground or whatever it's called is good.
Jorlain
Aug 24, 2022 05:11 PM
Vintageracer
Jan 10, 2020 05:33 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
355tpipickup
Aug 19, 2015 10:02 PM
stalkier
Aug 13, 2015 12:59 PM
