Fan hotwire <Quick help
Old Jun 11, 2004 | 08:43 PM
Incoming's Avatar
Car: 1986 Firebird T/A Streetracer
Engine: V8 350TPI
Transmission: Modified 700R4
Ok for the past 2 weeks my 1986 firebird T/A has been overheating... All my fan wires and sensers got deep fried when my fan got knocked out of position and got stalled (motor burned up and so did wires)... Im trying to direct wire my fan to a hotwire when the car is on... My problem is all the wires ive found so far dont produce enough power to run the fan at enough rpm to keep the car cool.. I really dont wanna run a hotwire to a switch. Ive gotten to many switches and gizmos in my car as it is.. Can someone please post a picture of a wire or area where there is a hotwire when the car is on.. Color named if possible.. Ive already tried testing lines but ive had no luck
Thanks Westley
Old Jun 11, 2004 | 10:03 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
When my coolant fan was hotwired, I discovered a wire mounted between the tan/white and black/red wires at the fan relay. Your wire colors may be slightly different based on year and model of the car, but the idea is the same.
CHECK YOUR AIR DAM! It's the thing underneath the car that usually gets knocked off when you run over a large speed bump or curb, and should be mounted to the radiator support. If its not there, you better put one there fast!
Old Jun 13, 2004 | 06:55 PM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Just an fyi...the air dam is really only there for highway driving. Thats when it functions the best. Thats what it was designed for. For city driving he needs to wire the fan.
Incoming:
Wish I could help you but I cant. Trickster probably knows. You can pm him. I had mine hooked directly into the fuse block (hotwired). But all it did was eat away the wire and block from sparking everytime I would start the car. I hooked mine up to a switch.
Bubbajones_ya
Jul 6, 2024 08:32 PM
armybyrd
Sep 28, 2023 12:16 AM
BrianI
Oct 3, 2015 12:57 PM
z28joe2
Sep 28, 2015 05:54 PM
64goatman
Sep 9, 2015 01:09 PM
