I Can't Reach Em!
Old Jun 14, 2004 | 06:44 PM
moreyes's Avatar
Car: 85 TA
Engine: 305 tpi
Transmission: 700
I Can't Reach Em!
How do I change the lil bulbs that go on the side blinkers on the fenders also the ones on the back. i cant figure it out
Old Jun 14, 2004 | 07:00 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
The front ones are easy, you just might have to get under the car to get them. Reaching in behind the air filter housing after its been removed and the vapor can moved out of the way gives you good access to the one on whatever side the air filter is on. For the one by the battery, you're probably better off going up from the bottom, twisting your arm along the way, or you can (re)move the battery...
The back ones are in behind the spare tire and behind the rear glove box. You have to remove the back panel to get enough room behind the driver's side interior quarter trim to reach the socket if the bulb is in the way. And the one behind the spare should be obvious...
ZZ3Astro
Aug 13, 2019 12:57 AM
FormulasOnly
Jul 23, 2018 08:47 AM
darwinprice
17
Oct 11, 2015 11:51 PM
FormulaEngland
Sep 30, 2015 01:50 PM
roysatikas
Sep 22, 2015 08:15 PM
