ECM problems
Old Jun 23, 2004 | 03:24 PM
83BlackBeauty's Avatar
Car: 83 Trans Am
Engine: 5.7 (350) TPI
Transmission: soon to be 700r4
Axle/Gears: 9-bolt rear. gears? hell if i know
ECM problems
here is some info so you have an idea of what we are messing with. About 8 Months ago my uncle did a engine swap for me, except he has no idea when it comes to wiring. The car is an 83 Trans Am, the donor engine was a 350 TPI, we have the fuel pump installed and we have fuel and spark just no injection. We think it is computer related. It looks like a tornado was under my hood and any help would be appreciated, I want to try and get her up and running today if at all possible. If i left anything out just yell, I have the car in my lot and can reply quickly.
Old Jun 23, 2004 | 03:47 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Are you using the original computer and what type of engine was in it originally?
Old Jun 23, 2004 | 04:14 PM
Car: 83 Trans Am
was hoping to get a reply from you Trickster, its an honor to meet and talk to you. I was on the boards just browsing and you seem to be the man i need to speak with. It was originally a 305 carbed, we just bought the book and my friend is helping me out, we got it to run for like 2 seconds and he is almost positive it is just the comp and something not talking.
Car: 83 Trans Am
oh and yes it is the original ecm. thanks a ton
Old Jun 23, 2004 | 04:32 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Did you get the GM service manual or the haynes- chilton manual. If you have everything wired up correctly, you probably just need to get a chip burned for it or you might be able to get by with a 305 TPI chip from a 85 model. Let me know how it turns out.
Old Jun 23, 2004 | 04:39 PM
Car: 83 Trans Am
we got the chilton one. I might even be able to get a chip, i know a boneyard around here has some 305 tpis laying around, but i don't think they have ECM's
Old Jun 23, 2004 | 04:48 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
If the ECM isn't in the car, a lot of boneyards pull them and keep them inside their storage areas. Get the part number for the chip from the dealership and go searching the boneyards. Make sure you get a chip that will fit in your original computer.
Old Jun 23, 2004 | 05:42 PM
Car: 83 Trans Am
also there are 2 blue ones and a clear one, the clear one isn't plugged in and has alot of wires coming out and all over
Old Jun 23, 2004 | 05:44 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Does the clear on have about 10 - 15 wires in it?
Old Jun 23, 2004 | 06:40 PM
Car: 83 Trans Am
yes it does, and it connects to the underdash, but im thinking the signlas are different or not going were they need to, we got some ticking, Nick believes its the injectors, and it ran for about 6-7 seconds this time
Old Jun 23, 2004 | 06:42 PM
Car: 83 Trans Am
I really wish i had a digital cam.
Old Jun 23, 2004 | 08:47 PM
Car: 83 Trans Am
Nevermind, we found out what was wrong, we just have to fabricate some wires, hook up the throttle cable, toss some an anti-freeze in and buy some gas, it will be running tomorrow, the exhaust is open right after the cat so it sounds real mean. There might be some misc wires, but im positive we can find it out.
Old Jun 23, 2004 | 08:51 PM
Car: 83 Trans Am
It ran fine with all the wires we needed in, and the second we took them out it died, so we know its all ok. Thank you all for your help :hail: (Trickster)
Eric2ndGen
Nov 5, 2015 01:51 PM
mddaniel
Sep 8, 2015 05:16 PM
inferno15
Aug 29, 2015 01:48 AM
355tpipickup
Aug 19, 2015 10:02 PM
djmarch
Aug 10, 2015 08:42 AM
