wire cliped under dashboard?
Old Jun 24, 2004 | 09:44 PM
FirebirdNYC's Avatar
Car: 1990 firebird
Engine: 3.1 v6
what is this cable that is cliped, iv learned to ignore it but it just bugged me again since i was down there today, one of the many sections of the wire that is cliped ,
cable that belongs attatched to the other
sorry bad pic ( thats the other end that is cliped )
okay so this wire seems to run from under my driver side dash , *pic 2 * and from there it runs through the driver side and into the hole *pic 1* from there it runs up through the fender and into the engine bay, sorry dont have that pic but i pulled out the end *pic 3*
any ideas on what the hell this could be??
Old Jun 24, 2004 | 09:51 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Just off hand without seeing it really close up, I would have to say that is the antenna coaxial cable lead.
Old Jun 24, 2004 | 09:52 PM
Car: 1990 firebird
Engine: 3.1 v6
you think so ? i can follow the antenna and everything is connected
Old Jun 24, 2004 | 10:04 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Does that wire look like it is a shielded cable? When I first saw the post, you hadn't added the other information in at the time. Does your antenna look like it is the original antenna or a replacement?
Old Jun 24, 2004 | 11:21 PM
Car: 1990 firebird
Engine: 3.1 v6
hm well it seems original to me, but at the same time it is very loose and wobbles, thats how i ran into that wire, i was trying to find a way to pull the wire tighter to tighten it, why would the other cable run from under the driver dash if it had to end up on the radio ? maybe the new antenna was routed more direct ., because i can see it leading behind the radio
p.s my car did come with an extra antenna when i bought it, it was in my hatch, but doesnt fit , its like the antenna screwd onto another piece, doesnt look like it fits my car but i could be wrong
Old Jun 24, 2004 | 11:52 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Do you have a standard antenna in there or is it a power antenna.
Old Jun 25, 2004 | 06:31 AM
Car: 1990 firebird
Engine: 3.1 v6
no its a standard screw on antenna
colton_carlson
Mar 8, 2019 12:21 PM
Caspar
Jun 19, 2016 11:19 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
