New steering colmun w\VATS
Old Jun 25, 2004 | 02:50 PM
azcamaro's Avatar
Car: 1987 IROC-Z / 1992 Corvette
Engine: 305 TPI / LT1
My car didn't have VATS. What do I need to make the VATS work? Do I need a new computer chip?
Can I still use the new colmun without hooking up the VATS? Or is it part of the ignition?
Thanks......
Old Jun 25, 2004 | 05:38 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
You can just use the steering column without the VATS. The ignition lock cylinder in it will work fine with your existing setup. If you are really interested in making VATS work. You will need a VATS control module, a starter enable relay, a properly coded key, a chip programed for VATS, the wiring for it, and the computer which would probably require more wiring. So just stick with the new steering column as is.
Old Jun 26, 2004 | 01:45 AM
azcamaro's Avatar
Thanks for the reply, Trickster.
That is exactly what I wanted to know. The colmun comes with the key.
Sounds like it would be easier to buy an aftermarket alarm.
A friend of my brother, has a 92' RS. Last week someone TRIED to steel his car. They cracked the steering colmun, but couldn't get it started, because of the VATS.
RS Reaper
Oct 17, 2018 07:52 PM
Ed1LE
Sep 30, 2018 09:14 AM
loud91rs
Oct 5, 2015 10:05 PM
sjorgens
Oct 1, 2015 07:54 PM
Night rider327
Sep 25, 2015 04:19 AM
