'89 RS Camaro - 2.8L MPFI... Gauge cluster doesn't work...
Old Jun 29, 2004 | 09:34 AM
Mr_Metal's Avatar
Car: '89 Camaro RS
Engine: LB8 V6 MFI
Transmission: T-5 5-speed
Axle/Gears: 3.42:1
OK,
I've finally got this car running the other day, to find out that the ONLY gauge that works is the Amps (ammeter) gauge.
The oil pressure gauge is pegged down at 0 (doesn't move), the fuel level gauge is pegged ABOVE full, and the tachometer registers 4500 rpm @ a true idle of about 900 rpm.
It's ALL screwed up !!
Has anyone had this sort of problem and remedied it w/ a new instrument cluster ?
Additionally, the factory radio isn't keyed ON... it will operate w/ the key out of the ignition. Is this normal ?
The battery goes dead every 3 days if it sits, so I'm thinking that radio may be a constant draw to the battery.
Any thoughts/suggestions to the above mentioned questions?
Thanks in advance for any help.
Frozer!!!
Jan 19, 2024 04:55 PM
Jeremys87
Jul 14, 2022 09:08 PM
BurlyChev
Aug 16, 2015 09:08 PM
fonzie85
Aug 13, 2015 11:50 AM
ChevyZ71
Aug 13, 2015 07:30 AM
