Removing Headlights and Motor assembly?
Old Jun 29, 2004 | 02:05 PM
GTA_JOE's Avatar
Car: 2 1988 GTAs
Engine: 5.0 and 5.7
Axle/Gears: 3.27 posi's in both
I am assuming that its the 2 upper screws and 2 lower screws that you need to remove to remove the entire Headlight assembly? I need to get it out to inspect, fix or replace my pop up motors. My question is, how do I get to the 2 lower screws to get the assembly out? The drivers side motor is totally frozen so I hope its not a case of having to lower the headlight to get to it.
Old Jun 29, 2004 | 03:25 PM
3GTAs1TA1Z28's Avatar
Car: 85 87 87 91 92
Engine: 305 TPI 350 TPI 350 Carb
Transmission: B/W T-5 and 700R4
Unbolt the motor from the headlamp swing arm and you can move the headlight down to get to the other bolts
Hope this helps
Old Jun 29, 2004 | 04:50 PM
GTA_JOE's Avatar
Car: 2 1988 GTAs
Engine: 5.0 and 5.7
Awesome. I'll give it a shot. Im hoping I can take the motors apart and see if I can just fix them. These things aren't cheap.
Old Jun 30, 2004 | 12:10 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
I found it is easier to remove the headlight bulb. Then youl'll have access to those two lower bolts using a socket, universal, extensions and a ratchet. I'll be revising the instructions I include with my headlight repair kit I manufacture when I get a chence.
Lon Salgren
Old Jun 30, 2004 | 08:13 AM
GTA_JOE's Avatar
Car: 2 1988 GTAs
Engine: 5.0 and 5.7
Im going out there in a little while and take them out. Hopefully you will be getting a call from me ordering a repair kit. I don't want to have to buy the entire motor.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
mhatfield 14
Aug 15, 2015 10:47 AM
stalkier
Aug 13, 2015 12:59 PM
3rdgenparts
Aug 8, 2015 07:09 PM
