Ignition choices for 305H
Car: 82 TA
Transmission: auto
I have decided to upgrade my ignition with the MSD 6A and wanted some imput on what coil and module to use. So far I have been looking at Hypertech's coil and cap kit, with oem module.I would like to find a coil and module that work together. MSD has one, but for 4 pin modules only. Car is 82 TA, 305 H. Any suggestions?
Car: 88 IROC-Z - original owner!
Engine: LB9 with K&Ns, MSD, Foil, Taylor
Transmission: WC T-5
Axle/Gears: BW 9-bolt, 3.45 posi
See my post in the thread on ignition modules. There are 3 companies in addition to MSD that make the control modules, and the other 3 make more than just the 4 pin versions. You can also get the 7 and 8 pin versions. If you have coil in cap, you don't need the 8 pin, it will be a 7 or fewer pin model.
Accel, Pertronix and one other that the name escapes me. You can get matched modules and coils from them all. If you go with a hot coil and module, you'll need gto upgrade the stock 7mm wires to 8mm.
RedLeader289
May 28, 2019 01:47 PM
gixxer92
May 18, 2017 11:20 AM
Gunner242
Dec 25, 2015 04:49 PM
