Dakota Digital FP gauge anyone have one?
Old Jul 9, 2004 | 12:23 PM
IroczInOz's Avatar
Does anyone have one of those Dakota Digital Fuel Pressure gauges installed in their car? I am thinking about getting 3 gauges, Volts,Trans Temp, Fuel Pressure and mounting them in the ashtray compartment like Willie did.
A few months ago I read that installing a FP gauge inside the car is unsafe? What is the connection on the Test Pressure port on the TPI? I have to ask Dakota if their sender mounts to it or will I need an adaptor.
Maybe someone knows.
MIke
Old Jul 10, 2004 | 10:18 AM
Morley's Avatar
If you are set on digital guages, try Cyberdyne guages. i have their FP guage in the 2 guage A piller pod. The guage uses an electrical sender which I have mounted on the firewall with a 12" #4 braided steel line connecting it to the schrader valve on the fuel rail.
Old Jul 11, 2004 | 04:48 AM
IroczInOz's Avatar
Thanks Morely I had a look at the Cyberdyne units and they just dont look as good as the Dakota ones. I actually foudn out that the Dakota use a 1/8" NPT fitting for the sended so basically I need a -4AN to 1/8" adaptor they are only couple dollars.
Old Jul 11, 2004 | 11:14 AM
Morley's Avatar
Since it uses capillary tubing and is a mechanical guage, you aren't going to be able to mount it inside the car, legally, too dangerous.
Old Jul 11, 2004 | 05:45 PM
IroczInOz's Avatar
No no it is not a mechanical gauge it uses and electrical sender so you just run electrical wires into the car: )
http://www.dakotadigital.com/Detail....-1/product.htm
Old Jul 11, 2004 | 07:35 PM
Morley's Avatar
Big $$$$ there. The Cyberdyne guage was half that (I know you said you didn't like it) Also Cyberdyne's are guaranteed for life
Lbibb
May 5, 2016 12:00 AM
rusty vango
Sep 29, 2015 02:44 PM
Gordonr1973
Sep 29, 2015 11:59 AM
Eric-86sc
Sep 28, 2015 11:37 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
