ecm problem
Old Jul 18, 2004 | 04:08 PM
sockfootball22's Avatar
Car: 84 z28
ecm problem
ok i have an 84 z28 with a 305. everything is basicly stock. i can't find where it is. i know its under the dash somewhere but what all do i have to take off? also what all has to be connected to pull the codes. i tried to pull them but the check engine light didn't even come on my brother disconnected alot of things so i don't know what is connected but with there help of my haynes manaul and the help of u guys i can find where everything is. thanks for all the help in advance
Old Jul 18, 2004 | 08:25 PM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Re: ecm problem
Remove the kick panel on the passenger side. Contort your body so that you can lay down and look up inside behind the upper wall. You will see it bolted up there behind where there would normally be a glove box. If not then its under the seat? You can use a paper clip to jump the ALDL to pull codes but if your SES light is not coming on there wont be any codes to show.
Old Jul 18, 2004 | 08:45 PM
Car: 84 z28
not to sound stupid but what does alda and ses stand for?
Old Jul 18, 2004 | 08:48 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Assembly Line Diagnostic Link = ALDL
Service Engine Soon = SES
Old Jul 18, 2004 | 08:49 PM
Morley's Avatar
ALDL= Assembly Line Diagnostic Link
SES= Service Engine Soon...Check Eng light
Eric2ndGen
Nov 5, 2015 01:51 PM
mddaniel
Sep 8, 2015 05:16 PM
inferno15
Aug 29, 2015 01:48 AM
355tpipickup
Aug 19, 2015 10:02 PM
djmarch
Aug 10, 2015 08:42 AM
