starts in nuetral but not park, that bitch
Old Jul 25, 2004 | 04:42 PM
plazek's Avatar
Car: 1988 formula firebird, 1989 dodgeramcharger
Transmission: one that works
just got a new/old 88 firebird formula, the bitch wont start in park, yet when i put it in nuetral it will start right up. help.
Old Jul 25, 2004 | 04:45 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Try adjusting the park/neutral switch, it's on the right side of the shifter inside the console. You'll have to take off the shifter **** and console top to get at it. There are two screws that secure it to the shifter. Loosen the screws a little and try sliding the switch back a little until you can start it in park.
Old Jul 25, 2004 | 04:54 PM
plazek's Avatar
already tried to wiggle it around i cant get the bottem clip off to move it more, any other sugestions?
Old Jul 25, 2004 | 04:57 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
What bottom clip is that?
Old Jul 25, 2004 | 04:59 PM
plazek's Avatar
On the wiring harness going into the shifter there is a clip on the top side and bottom. I cant reach the one on the bottom cuz of the console and shifter being in the way. Or is that not the switch im looking for???
Old Jul 25, 2004 | 05:01 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
No, that should be the one. Are the wires keeping you from sliding it more?
Old Jul 25, 2004 | 05:03 PM
plazek's Avatar
ya they in the way too. Should i just clip the two big ones to bypass the switch completely??
Old Jul 25, 2004 | 05:04 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You could, but I wouldn't go for the quick fix, personally.
Old Jul 25, 2004 | 06:26 PM
plazek's Avatar
found that the harness had already been messed with before. We cut the two big wires and soldered them together to make the switch think it always in park. It will work for now until i go get a new harness.
Orr89RocZ
Apr 25, 2016 08:28 AM
Bryan F
Aug 18, 2015 02:28 PM
Winchester1094
Aug 18, 2015 10:23 AM
92camaroJoe
Aug 13, 2015 06:07 AM
