VSS power?
Old Jul 25, 2004 | 11:23 PM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
VSS power?
here's the Question. On early model thirdgens w/ an optical sensor VSS, did the actual sensor need power? i'm not asking if the small buffer box (little yellow thing) needed power, as i know it would to convert a signal, however would the regular sensor? The questions comes from a thought on why would there be three wires, red/green/black coming from the yellow box, and all going into the sensor, as if there was no power needed at the sensor then u'd only have two....maybe one.
Also, on the later model thirdgens w/ a VSS in tranny...what wire carried the signal...should be a yellow and a purple wire, are they interchangable as to which gives signal, and which is grounded? That's the only explanation on those i could find from the search engine. Thanks in advance.
Old Jul 26, 2004 | 12:41 AM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
On the 'birds with the buffer box, the yellow and purple wires run directly from the box to the sensor on the trans.
I couldn't find any info on the optical sensor, but would assume that red is positive, black is ground, and green sends the signal to the ECM.
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
Slush92RS
Sep 2, 2015 08:56 PM
GTAman
Aug 27, 2015 10:29 PM
sailtexas186548
Aug 24, 2015 10:11 PM
