V6 to V8 swap, question about alternater
Old Aug 2, 2004 | 06:53 PM
Camaro_nut's Avatar
I have the new motor in ( Ramjet 350) and the engine
accessories on. I noticed that the alternater has a 4 pin
regulator on the back of it. This is from the GM peformance
serpentine belt system, and is actually just like the 91-92
F body belt system. I need to know why there are 4 pins,
when there are only 2 wires that are there on my existing
alt. connector? The electrical diagram in the GM service
manual for the charging system only shows 2 wires going
to the alternater/generator, either V6 OR V8. Both wire up
almost identical. So, are the other 2 pins not used? There
is also wire that connects to the back of the alt. on the
stud right?
The belt system came with a 4 wire connector. But, why?
I even checked with a GM dealer and aftermarket places,
all carry a 4 pin alt. for the 5.7L. Does anyone actually
have a 4 wire connector going to the alt.? I have seen
pics around here with 5.0L/5.7L using only 2 wires going
to the alt. So, the other 2 are just not used? Any help
appreciated, thanks!
P.S. PLEASE post pics of the alt. and wiring if you can. Thanks!
Old Aug 2, 2004 | 08:07 PM
AaronIROCZ's Avatar
Moderator/TGO Supporter
If you still have your stock wiring intact for the alt. just use it over, I just checked all 3 of my cars and they only use 2 wires. Hope this helps, I can scan a wiring diagram for you tomarrow night from a 88 transam factory service manual if you want. Let me know.
Old Aug 3, 2004 | 04:54 PM
Camaro_nut's Avatar
I kept the original stock wiring intact for everything but
the old ECM from the old motor. So the alt. wiring is still
all there. I checked my GM service manual for 1991 Camaro
and both the V6 and the V8 wire 99% the same. But I also
need to know if your V8 cars have 4 pins in the alt.
Disconnect the alt. connector and check to see if there
are 4 pins in the voltage regualtor. If there are, then I have
the right alt. for my car and the other pins are not used.
Thanks for your help! Please get back to me as soon as you
can. I appreciate your help.
P.S. You can scan and send the diagram here if you'd like.
The more info I have the better. Thanks.
Old Aug 3, 2004 | 05:51 PM
AaronIROCZ's Avatar
Yes all of my cars have the 4 pins in the alt. I forgot the manual at work I will try tomarrow
Old Aug 3, 2004 | 06:23 PM
Camaro_nut's Avatar
Ok, so only 2 pins are used, the others are not. Thanks
for clearing that up for me. I don't need a new alt. or need
to modify my wiring. I wonder why they made it a 4 pin
when only 2 pins are used?
Old Aug 7, 2004 | 06:39 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
All GM gens have 4 pins at the plug which is actually part of the regulator IC. It is used for different applications. Thirdgens usually only use 2 of the four connections, one for field and one for the sense or turn on wire. Go to www.alternatorparts.com the have an online service manual with a diagram.
Old Aug 7, 2004 | 11:34 AM
Camaro_nut's Avatar
Thank you, Danno for the info!
And also AaronIROCZ, for the info too!
Frozer!!!
Jan 19, 2024 04:55 PM
theurge
Aug 21, 2015 12:46 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
