Which alternator to get?
Old Aug 4, 2004 | 07:41 PM
Oddball's Avatar
Car: '86 IROC-Z
Engine: LG4 305-4BBL
So my Choke / Alternator light has been intermittently going off when starting and I noticed my headlights flickering very slightly. I searched the boards and the overwhealming recommendation to to replace the alternator.
Going to advanceautoparts.com / partsamerica yields a number of choices for my 86 IROC LG4. Do you have any makes / models you recommend?
Old Aug 7, 2004 | 06:47 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
Best bet is the AC Delco stock replacement. Most of the chain store stuff is junk. They use a lot of low quality offshore components during the rebuilding process. AC Delco rebuilds meet GM standards for new units. 100 amp AC Delco gen should be fine.
Old Aug 7, 2004 | 07:34 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
A/C Delco new 105 amp would be the best choice.
Old Aug 7, 2004 | 12:22 PM
Oddball's Avatar
Car: '86 IROC-Z
Thanks for the advice. When I had the whole charging system tested, the guy said the alternator was fine and I probably had a loose wire. I'm going to try and go over all of the connections to the alternator and choke to see if something is loose.
RS Reaper
Oct 17, 2018 07:52 PM
apie2546
Oct 16, 2016 02:24 PM
SRKLEGIN
Oct 3, 2015 10:11 PM
RS Reaper
Sep 27, 2015 07:04 PM
raymondandretti
Sep 27, 2015 06:43 PM
