wirring the heater
Old Aug 3, 2004 | 08:34 PM
Rick King's Avatar
Car: 1987 TA
Engine: 350 stock/twecked
wirring the heater
ok I got the carb 350 in and removed the tpi and computer + harness.. I got the fuel pump wired, I am having a proble figuring out the heater controls. I need a way to wire in the blower motor that looks good and alowes it to work properly.
thanks in advance for all the help.
Please help so I can send this beast off for paint and then a cruzz
later and
GB
rick:hail:
Old Aug 4, 2004 | 05:42 PM
kevinc's Avatar
Car: 1982 Z28
Find the big red wire in your heater/AC blower harness. Should have a single-pin connector on it, where it used to connect to your TPI engine harness. Start at the wiring that connects to your blower box and trace it back to the firewall, somewhere along there you'll find the connector sticking out.
Bring a fused or fusible-linked 12VDC off the starter pole where the other fusible links are, to that connector.
Should be in business.
Formula8r89
Sep 22, 2015 04:24 PM
BWilcox
Sep 20, 2015 12:19 PM
