relocation the battery..a little help
Old Aug 5, 2004 | 01:10 PM
iggy1991's Avatar
Car: Red 91 RS Camaro
Engine: LO3 with Comp Cam
Axle/Gears: 4th gen rear
So I'm trying to move my battery to the trunk. I already have a 4 gauge power wire running my amp so can I just use that power wire as the hot wire and ground the battery to the chassis. I'd also connect that hot wire to the red battery wire under the hood and connect the black battery wire to the frame....will this work or will it ground itself out?
Old Aug 14, 2004 | 03:16 PM
Tyler-88's Avatar
power wire from battery goes to the stater solinoid. ground goes to the chassis. make sure your engine is grounded as well
Old Aug 16, 2004 | 08:59 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
what guage should be used for positive when are running such a large length of it like that ?
and where do you run the hot cable along at ?
how do ytou mount the battery and where ?
box for it ?
aftermarket box or homemade ?
if homemade then out of what is it made ?
steel ?
thick plastic ?
thanks
Old Aug 16, 2004 | 09:25 PM
TheGreatJ's Avatar
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
Transmission: 700R, T56, 700R4
4 gauge is the absolute minimum. I use and recommend 2 gauge for both power and ground. It helps if you have a gear reduction starter as they draw less current.
Most guys put it in the spare tire well.
Some use a battery box, some just strap it down. To pass a tech inspection you have to have a sealed box which is vented outside the car.
grngryoutmyway
Oct 18, 2016 05:48 PM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
89newfun
Sep 16, 2015 09:28 AM
