Vats!!
Old Aug 5, 2004 | 09:06 PM
dennine2's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Vats!!
Working on a 1989 camaro. Put the engine of another Camaro into this one and didn't know until later that the other engine had VATS.
Got ignition from old car but had to go get VATS wiring from a junk yard car. Used the same module that was in the old car.
Now this car will NOT run AT ALL.
The fuel pump comes on but that is it??? ANY ADVICE ASAP!!
Been working on this car for 3 days......
Old Aug 5, 2004 | 10:10 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Actually it isn't the engine that had the VATS, it was the computer that you put in the car to go with the engine. Did you also get the starter enable relay. By the way, I just noticed that it is a 1989 camaro that you are working on. The car already had VATS on it before you put the other engine in it.
RS Reaper
Oct 17, 2018 07:52 PM
djmarch
May 8, 2016 11:32 AM
AmorgetRS
Sep 28, 2015 09:33 PM
86White_T/A305
Sep 21, 2015 05:28 PM
Winchester1094
Sep 15, 2015 09:48 AM
