temp gauge
Old Aug 8, 2004 | 04:27 AM
trendkill92's Avatar
Car: 1989 camaro RS
temp gauge
I know that this has been post a million times, but I can't seem to find the right help. I can see clearly under my hood that the green temp. gauge wire is not connected to anything, however, I can't seem to figure out where the hell it connects to. I keep hearing that its suppose to connect to the head on the driver's side near spark plug 1. I'm going nuts trying to figure out where it connects at.
I have a 89 camaro RS and the connector end is a slim white plastic piece if that helps.
Old Aug 8, 2004 | 04:49 AM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Transmission: 6 speed
It is in the head on the drivers side.It is really close to the exhaust manifold so you can't see it.Feel around(while cold!).It is right above the #1 spark plug.
Old Aug 8, 2004 | 12:21 PM
Car: 1989 camaro RS
I still can't find it. All i can feel about the #1 spark plug is a bolt with a nut on it.
Old Aug 8, 2004 | 12:53 PM
NoTransistors's Avatar
Car: '83 Firebird S/E
Engine: The Chevy 305. with carburator
Transmission: 700R-4
I had trouble finding it, too. Finally got a visual on it. Used a droplight. Seems to have a tiny brass nub that the connector slides onto. Good luck.
Old Aug 10, 2004 | 03:54 AM
Car: 1989 camaro RS
Well I finally found where to hook the wire up to last night when I changed my oil and was under my car. I also helped my buddy out(he had the same problem). But I would like to thank all that helped. Without your help, I would have been looking forever to find where to connect it to.
Bubbajones_ya
Jul 6, 2024 08:32 PM
ULTM8Z
Oct 2, 2015 01:25 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
ironbmt
Sep 27, 2015 06:00 AM
corey8084
Sep 17, 2015 02:56 PM
