speedo connect?
Old Aug 10, 2004 | 12:17 AM
SuperHeavy92's Avatar
Car: 1992 Camaro RS
Engine: LO3
speedo connect?
Okay, I have a 92 TBI camaro that i recently converted to TPI.....only prob is the wiring harness i used came from an auto and i have a manual. now there's a 3 wire connector for the tranny where i used to have only 2. i'm assuming its for the speedo (already hooked up the VSS and it works fine). been studying wire diagrams for weeks and still cant make sense of it. possibly have to re-wire it at the ecm?? hope someone can help...my brain's fried on this one. thanks
Old Aug 10, 2004 | 08:32 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
That three wire connector would be for the Torque Converter Clutch solenoid that is on Auto transmissions. The connector for it is located on the tranny case above the pan on the left side.
Old Aug 13, 2004 | 12:20 AM
Car: 1992 Camaro RS
Engine: LO3
only prob is i have the t5 tranny, not an auto. my tranny's got 2 connections on it. 1 is for the VSS and the other is a 2 wire connection with one blue and one green wire. any clue what to do?
Old Aug 13, 2004 | 11:18 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
back up(reverse) light switch
Old Aug 13, 2004 | 05:09 PM
Car: 1992 Camaro RS
Engine: LO3
hahaha....well i feel dumb. so if thats got nothing to do with my speedo....why wont it work? vss opperates fine. thought the speedo got its signal from the vss.
Old Aug 13, 2004 | 10:57 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Okay,
Has your car ever been a automatic? Also the 305 TBI cars used a VSS buffer box for the automatics. The 305 & 350 TPI engines operated off the VSS on the transmission. Do you have something like a box under the dash next to the ECM with two connectors and seven wires total. That would be the VSS buffer box.
Old Aug 14, 2004 | 06:27 PM
Car: 1992 Camaro RS
Engine: LO3
car started out as a 305 TBI with the 5 speed manual. now i'm running TPI with a stock harness from an auto trans am, and the 7730 ecm. all gauges and sensors work except for the speedo and related oddometer.
rs_z28_vert
Sep 30, 2015 09:47 PM
bplessy
Sep 30, 2015 12:14 PM
Gordonr1973
Sep 29, 2015 11:59 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
