LED Dome
Old Aug 17, 2004 | 10:22 AM
Goumba T's Avatar
Car: 1990 TA
Engine: LB9 305
Transmission: 4L60
LED Dome
My dome light bulb died do I decided to try one of those LED ones in the store since it was supposed to be brighter. Maybe without the lens it would have been.
With the light is on, it works properly. When the door is closed and the switch is off, the 2 middle bulbs came on, but at very low intensity.
Is this normal, or do I have a wiring problem somewhere? I'm guessing the low draw isn't enough to light up an incandescent bulb at all but just enough for the LED to light a little.
Old Aug 17, 2004 | 12:44 PM
TheGreatJ's Avatar
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
Transmission: 700R, T56, 700R4
That's a possibility. Electrical interference can also cause an LED to come on very dimly. I have this problem with the high-beam indicator LED in my custom dash. If the car is running, the electrical "noise" from the ignition system will keep the LED dimly lit....not enough to see during the day, but just barely noticable at night. Oddly enough, the turn signal LEDs which are right next to it don't do this.
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
RedLeader289
May 28, 2019 01:47 PM
Fronzizzle
Feb 9, 2017 09:31 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
