update on my charging system...
Old Aug 17, 2004 | 10:31 PM
ponykiller1992's Avatar
Car: 89 formula 350
Transmission: Stock 700r4
Ok, I checked the wires the best I could from the top of the motor, and all seems good. I went to start it, I had 11.5 volts, but the started started to turn, then started clicking. My question is, if there is a loose connection at the starter, could that cause a voltage drain, and possible explain my no start even though I have enougb voltage?
Old Aug 18, 2004 | 10:30 AM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
You dont have enough voltage. You should have at least 12v to get it to start and 12v is almost completly drained. A fully charged battery is about 12.8v. The symptom you describe also indicates a dead battery.
Old Aug 18, 2004 | 10:15 PM
Car: 89 formula 350
ok, I charged it up real good, and when I turned the key on (not starting it) I had 13.5 volts. As soon as I started the car it dropped to 12.8. I gave it some load (turned the AC on) and it just started draining. Went all the way down to about 9v. I turned of the AC, and it went up to 10v, but would go higher. I turned the car off, tried to restart, and got the infamous clicking. I even tried the old take battery disc while running, and it died instantly. Also, it seems I can only fully charge the battery (13.5) when the ALT is disconnected.
Old Aug 18, 2004 | 11:51 PM
dankhound's Avatar
Car: 91 RS
Your alternator is definatly bad if its putting out that low of a voltage. You battery may also be bad. I would have that checked out before putting in a new alternator because a bad battery will kill a new alternator very quickly.
Old Aug 21, 2004 | 05:44 PM
Car: 89 formula 350
Well, had the Alt tested, it was ok. Had the batt tested again, tunrs out it was bad. So, I got a new battery, charged it up good, started the car, and I still have 12 volts. The volts dont go down when I put load on it (well, they go down, but it comes back up). I am really confused on this. I dont know why I only have 12 volts. I check all my wires, and they look ok. What the hell can be causeing this?
Falcon50
Aug 22, 2020 03:26 PM
apie2546
Oct 16, 2016 02:24 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
RS Reaper
Sep 27, 2015 07:04 PM
