Quick Gauge Cluster Questions
Old Aug 19, 2004 | 10:34 PM
Benm109's Avatar
Car: 1991 Chevy Camaro
Engine: 305 TBI
I am removing my stock gauge cluster so I can replace some burned out bulbs. Everything has gone smoothly and I got it out successfully. My question is in regards to the needles on all of the gauges. Do they have to be in the same place (when the gauge cluster goes back in) as when the car was first turned off? For example, when I turn off the car the speedometer was at 0 MPH, of course. Now it is on 15 MPH. So, is it necessary to keep the needles where they were, or not? My Haynes manual (good for nothing) says nothing about this.
P.S. I drew a picture and labeled where the needles were on all of the gauges before I started, just in case.
Old Aug 19, 2004 | 11:02 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Of course they won't tell you anything about this. BTW, you didn't need to remove the needles to start with and I hope that you disconnected the battery first. When I had my whole cluster apart, I reset the needle at zero when I put it back on. The tachometer needle was a different story, I had to manually push the needle back to zero with my finger three times before I had it right. It still reads about 100 RPM high but it was doing that before I took it apart
Old Aug 20, 2004 | 07:48 AM
Benm109's Avatar
Engine: 305 TBI
Yes, I disconnected the battery and disconnected the airbag, just in case. I didn't take the needles off, they just moved a little bit. Thank you, once again, Trickster :hail: !
Old Jan 11, 2008 | 02:50 PM
cyberleader's Avatar
Car: 2002 Z28
Engine: 5.7 Stock
Axle/Gears: Stock
Re: Quick Gauge Cluster Questions
Frozer!!!
Jan 19, 2024 04:55 PM
Jeremys87
Jul 14, 2022 09:08 PM
fonzie85
Aug 13, 2015 11:50 AM
ChevyZ71
Aug 13, 2015 07:30 AM
