For the professionals
Car: 1982 Firebird SE
Engine: 350 V8 4bbl (H)
Transmission: TH 350 Automatic
Headlight Relay switches question?
The 82' Firebird has 3 relays for the headlights to function properly.
2- Actuator relays, which connect to the wires from the headlight motors.
1- Isolation relay, which attaches to the front of the car. This allows power to be sent to the actuator relays (as i understand it)
My question is:
I purchased all 3 relays and even though the Isolation relay was $10 more, they all look the same. Even the plug pattern looks the same. Is there some internal difference? I realize the actuator relays only have 5 total wires and the Isolation relay has 6 wires to it but, the relays LOOK identical.
Please clarify for me.
Thanks, Randy
My question is:
Thanks, Randy
Car: 1989 Iroc-Z
Engine: 5.7L TPI
As you have noticed by the connections, the isolation relay has six wires while the actuator relays have only five wires. Here is a schematic that will show the internal differences between them. This schematic is out of a 1982 firebird GM service manual.
Thanks for the info. I put a new Isolation relay in and voila, the lights go up and down just fine now.
This was a real learning experience for me. I am not sure why they don't label them Isolation and Actuator on the actual relays. This certainly would avoid some of the confusion. They look outwardly identical!!
thanks, Randy
thanks, Randy
