TPS help
Old Aug 23, 2004 | 09:40 AM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
TPS help
Just put in the new motor, but this issue has been lingering for quite some time, dating back to the tired 305.
TPS will show normal at idle, and when setting it... .54v or around depending on where I set it at...
But when going to WOT, or simulating WOT, it only gets to 1.27v. Still though would go to Cell 15 (WOT) when the 305 was in, and go to the PE tables...
dumbfounded, and I am going to check the readings via multimeter today...
All numbers up to now are from an Autoxray scanner, but what the scanner tells you is what the ECM actually sees, so i doubt the numbers will be different from a multimeter...
Thanks guys.
Old Aug 23, 2004 | 09:59 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
Make sure your actually getting the 5v reference to the sensor.
92camaro350cci
Oct 14, 2015 09:29 AM
Fred SS
Oct 12, 2015 11:27 AM
HoosierinWA
Oct 7, 2015 10:15 AM
racereese
Oct 3, 2015 03:46 PM
