Wiring diagram needed!!!
Old Aug 21, 2004 | 06:03 PM
ffvetteman's Avatar
Help I need a wiring diagram for a 1989 Camaro 305 TBI auto C203 computer connector!!!
Can someone help?
Thanks so much
Old Aug 21, 2004 | 07:13 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Of course, it is part of the cruise control harness and is located under the dash on the drivers side. You will see the wiring for it in the second picture.
Old Aug 21, 2004 | 07:14 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
page 2
Old Aug 21, 2004 | 07:54 PM
ffvetteman's Avatar
That will be helpful, but I need the diagram of the C203 connector (that comes off the ECM and goes to the dash area) with all the ports listed as to what each wire is for.
Old Aug 21, 2004 | 08:08 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Connector C203 doesn't go to the ECM, it goes to the cruise control module and the cruise control in the engine bay. Do you mean connector C207 which is located under the dash on the passenger side and has about 15 wires in it?
Old Aug 23, 2004 | 03:37 PM
ffvetteman's Avatar
I could be wrong on the name, so I'll try to describe it.
Off the computer there is a series of wires that go to the right kick panel, and into the engine bay. I dont need that one(yet).
Then there is a group of wires that go toward the drivers side. What I'm looking for is a pic of that connector with a listing of what each pin is for.
Old Aug 23, 2004 | 06:50 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Would this be the one that you are talking about? It is connector C207 and is located under the dash on the passenger side near the ECM. BTW, I deleted your duplicate posts and the WTF.
Old Aug 23, 2004 | 08:50 PM
ffvetteman's Avatar
Thanks for deleting and I'm not sure how the multiple posts got there.
I think thats what I am needing!!
Thank you very much!!!!!!
Old Aug 23, 2004 | 09:12 PM
ffvetteman's Avatar
That worked!!!
Now would you by chance have the same connector for a 86 T/A 305 carb auto??
Old Aug 23, 2004 | 10:05 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Originally posted by ffvetteman
That worked!!!
I can have one together by tomorrow evening for you.
Old Aug 23, 2004 | 10:12 PM
ffvetteman's Avatar
If you could that would be incredible!!!
Thank you so much!!!!!!!!!
Caspar
Jun 19, 2016 11:19 PM
IROCZ1989
Jan 24, 2016 03:55 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
