Temp Gauge
Old Aug 26, 2004 | 11:03 AM
Pdiminico's Avatar
Car: 88 IROC
Engine: 5.O TBI
Temp Gauge
When I bought the Car an after market gauge was installed below the Steering column. The green sensor lead for the Stock temp gauge is not connected. My temp gauge is pegged off the scale .
Is the stock gauge designed to peg to the North when it is not connected?
Old Aug 26, 2004 | 12:20 PM
REALPOWER's Avatar
Car: 1984 Camaro on steroids/ 1987 iroc-z28 5 speed.
Engine: 383 nitrous motor / poindexter 305
Transmission: Th350
No, that means that it is grounded somewhere....most likely the wire is melted to the AIR tubes by the headers, mine does this now and then.
OR
You need to smack the dash a few times because the needles are notorious for sticking either up or down.
Old Aug 27, 2004 | 11:29 AM
Pdiminico's Avatar
Car: 88 IROC
Engine: 5.O TBI
The wire has not made contact or melted. The gauge stays pegged without the key in the ignition.
I have tried to smack the dash a few times but it does not move.
Old Aug 27, 2004 | 11:33 AM
REALPOWER's Avatar
Transmission: Th350
Smack harder!! I usually put my fist right behind the steering wheel and smack it pretty hard...it takes a few hits!
Old Aug 30, 2004 | 12:46 PM
Pdiminico's Avatar
Car: 88 IROC
Engine: 5.O TBI
It's amazing what a good punch against a gauge will do!! Next I will plug it into the sending and see if it works.
Thanks!!!
Old Sep 9, 2004 | 12:49 AM
cIaRmOaCrZo28's Avatar
Car: 1989 Iroc-Z Camaro
Engine: 5.7 liter 350
hmm...wonder if this will work for mine, its ALWAYS stuck up...mechanic said to replace...but I havent tried hittin it really hard...only tapping it with my finger
Old Sep 9, 2004 | 12:52 AM
no luck....it moved down about half way one hard hit...but then right back up...any clue what would cause this? or just bad gauge? used to work....b4 maf sensor went....maybe this is whats causing my service engine light
Old Sep 9, 2004 | 07:48 AM
Pdiminico's Avatar
Car: 88 IROC
Engine: 5.O TBI
My gauge also went back to where it was. I found someone that was selling the stock gauge. Just waiting for it to arrive in the mail.
Bubbajones_ya
Jul 6, 2024 08:32 PM
ULTM8Z
Oct 2, 2015 01:25 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
ironbmt
Sep 27, 2015 06:00 AM
corey8084
Sep 17, 2015 02:56 PM
