Hi-beams not working...
Old Aug 26, 2004 | 09:34 PM
UmmaGumma's Avatar
Car: 2007 Infiniti G35 SEDAN
Engine: 306HP 3.5L V6
Transmission: Auto Pilot Baby!!!!
Axle/Gears: Don't care!
All of a sudden the other night when I went to turn them on.. no click.. nada.. It almost seems as though the switch in the steering column is gone.
Any suggestions? If this a PITA fix or is it pretty painless?
Chris
Old Aug 26, 2004 | 09:48 PM
onebinky's Avatar
There should be a little plastic trim piece behind the switch, make sure that's still in place. If it's not, the whole switch assembly will pivot with the lever and it won't click over.
If that's not it, the switch is probably broken.
Old Sep 2, 2004 | 11:15 PM
91CamaroDude's Avatar
Car: 91 Camaro RS, BEAST
Engine: 305 TBI
same thing happend to me a few nights ago. I took off the plastic cover on behind the high beam switch and pieces just fell out I found that the highbeam/turnsignal lever actually pushed a 2 foot long metal rod down the to REAL highbeam switch that is almost above the brake pedal. My pieces in the column were broken for good so i ripped out the metal rod and pulled the actual switch (that was riveted on) up the the left side of the dash, so i now have puch button highbeams
Will post pix tomarrow...
hope that helps :lala:
Old Sep 4, 2004 | 01:06 PM
Engine: 305 TBI
here
Old Sep 4, 2004 | 01:08 PM
Engine: 305 TBI
the new switch, being mounted directly under the headlight ****
Tigerof
Jul 30, 2019 04:01 AM
TA87GTA
Aug 26, 2011 08:43 PM
88fastgta
Sep 8, 2009 12:09 AM
Dingley
Apr 23, 2005 01:02 AM
