Brake Pedal Switches
Old Sep 3, 2004 | 12:33 AM
moneyman380's Avatar
Car: 1991 Z28
I have a 91 z28 and i just noticed that there are two switches above the brake pedal. Im guessing one is the brake light switch, but what is the other one? Im asking because i also noticed one is jammed in stuck and the bracket is bent that holds it, but my brake light works.
Old Sep 3, 2004 | 01:43 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Torque converter clutch and/or cruise control.
Old Apr 10, 2008 | 03:48 PM
gearhead0384's Avatar
Car: 1989 Camaro IROC-Z
Engine: L98 350 TPI
Transmission: Built TH-700 R4 (Vilgilante 2800)
Axle/Gears: 9 bolt w/ PBR's
Re: Brake Pedal Switches
I just realized that one them (the TCC/Cruise Control switch) is broken where the threaded portion meets the boxed portion. From the looks of it rod or plunger what, ever it maybe, is always in the engaged position. Besides making the Cruise control not work what other effects would this cause?
Kevin
1992 Trans Am
May 10, 2023 07:19 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
redmaroz
Aug 16, 2015 11:40 PM
johanlindgren
Aug 16, 2015 12:16 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
