Fuel pump voltage??
Old Sep 5, 2004 | 09:33 PM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
Fuel pump voltage??
What should the voltage be at the fuel pump on a TPI car? What should it be with the key turned on, at idle, and at WOT? I'm not getting any fuel pressure (only 25psi) and the pump only has 9 volts with the key on.
Old Sep 5, 2004 | 10:07 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
With a fully charged battery and everything working as it should. The voltage should equal battery voltage.
Old Sep 5, 2004 | 10:10 PM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
So, from idle to WOT voltage should be 12+ volts? Would having only 9 volts cause my fuel pressure problems?
Old Sep 5, 2004 | 10:12 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Yes because the pump is not working at full power.
Old Sep 5, 2004 | 10:19 PM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
Excellent, thanks for the quick reply. I guess I need to re-wire to allow for 12 volts all the time.
Old Sep 5, 2004 | 10:24 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
How do you have it wired now? Are you by-passing the ECM and fuel pump relay?
Old Sep 6, 2004 | 12:23 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
I wouldn't re-wire because you'd be bypassing the engine's proctection circuit against loss of oil pressure. If that's not a problem then just tie together the 2 wires of the fuel pressure switch connector.
Old Sep 6, 2004 | 01:40 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
If your talking about the oil pressure switch cutting off power to the pump if oil pressure drops below 4 psi, that's a common belief, but incorrect. The oil pressure switch merely acts as a backup to the relay.
if you look at the diagrams, the power out from the oil switch is spliced into the power out wire from the relay. If the relay fails, the pump is powered by the switch, assuming 4 psi oil pressure.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
89GTAOz
May 16, 2020 09:31 AM
92camaroJoe
Aug 13, 2015 06:07 AM
