Speedo, Cruise, Service light, shift, all related??
Old Sep 11, 2004 | 10:29 PM
camarosource's Avatar
Car: Custom 1992 Camaro Z28 25th Anniver
Engine: 5.7L V8 350 L98 TPI
Recently my speedo needle stopped working (1992) and it's been said that it is likely to be the speed sensor that has died.
Yesterday I've noticed at a certain speed that the transmission seems to not shift all the way (auto). Almost like it's in the MIDDLE of a high shift and a low shift.. as if the speed is INBETWEEN because it keeps shifting in and out.
TODAY I discover my CRUISE control is DEAD.. AND suddely my "Service Light" is now coming on.
This seems all so coincidental to be all different problem so can that speed sensor be causing ALL OF THESE?? None of these has appeared until that speed needle died.
If it is not the sensor, what could cause all these?
Thanks very much.
Old Sep 11, 2004 | 10:34 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
If I had to hazard a guess, I would say that the code is 24 (Vehicle Speed Sensor VSS) and yes the cruise control is linked to the VSS.
Old Sep 11, 2004 | 10:44 PM
And the MIDDLE shifting tranny? Almost as if your speed is at the very MAX of the gear before it, and the VERY BEGINING for the next gear so the tranny is switching for 1 gear to the other back and forth until you either deccelerate or accelerate a bit more.
Vintageracer
Jan 10, 2020 05:33 PM
Hellbillydeluxe
Sep 22, 2015 09:58 PM
Jae992
Aug 27, 2015 09:07 AM
apie2546
Aug 10, 2015 05:43 PM
Omega
Aug 10, 2015 12:46 PM
