Engine Grounds
Old Sep 15, 2004 | 07:28 AM
Charlz B.'s Avatar
Car: 87 IROC-Z
Engine: LB9
Engine Grounds
Where does the ground strap at the back of the LB9 connect on the block at? Anyone have a picture? Where are the other grounds at? Thanks...
Old Sep 15, 2004 | 09:27 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
It connects to a bolt at the back of the right cylinder head. There is another engine ground on the back of the left cylinder head.
Old Sep 15, 2004 | 09:42 AM
Charlz B.'s Avatar
Car: 87 IROC-Z
Engine: LB9
Thanks Trickster....
I had a little fire yesterday, apparently fried that ground I referred to. I love watching smoke trickle out near the distributor coil. Now the power windows, windshield wipers, headlights, etc..all hardly work, and VERY slowly at that.
Is there any easy way to get to those grounds? And what about heavier straps...seems like paying 4$ each for the same little aftermarket rust straps isn't necessarily the best option.
Old Sep 15, 2004 | 09:59 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
There isn't a per se easy way to get to those ground on the right side. I have a MAC flexible head 1/4" ratchet that I use after moving a few items out the way. you could probably do it with a good wrench and a lot of patience. As far as those grounds, go to a junkyard and get some from the cars there, doesn't matter what car. They are all basically the same.
Old Sep 15, 2004 | 10:56 AM
FruityOne's Avatar
Car: 1989 TransAm GTA
Engine: One sweet modified 355 TPI.
Transmission: The kind that shifts....
Or you can go to a parts store to buy new ones. Its not like grounds are very expensive at all.
Old Sep 15, 2004 | 11:02 AM
Charlz B.'s Avatar
Car: 87 IROC-Z
Engine: LB9
No they're not, I agree. Is there any benefit to using something like 4 or 8 guage insulated wire?
Old Sep 21, 2004 | 06:40 PM
Verviticas's Avatar
Engine: L98 5.7
i would say so, and even if there is no benifit, at least it can rust for longer before becomming useless. haha
BRoss99
Aug 10, 2025 05:08 PM
E Rod
Aug 28, 2015 05:17 AM
Jae992
Aug 27, 2015 09:07 AM
justin57
Aug 20, 2015 07:05 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
