power windows acting up
Old Sep 15, 2004 | 02:49 PM
F-Bobby's Avatar
Car: 1989 Formula 350
Engine: Stealth Rammed 350
Axle/Gears: 3.45 9 bolt
OK so like 80% of the time my power widnows dont work. There is a loose connection somewhere under the dash cause fi i mess around with the wires under there by kicking them then the windows sometimes start working. Ive looked at the large pink wire that goes inot eh back of the fuse panel and that is in there solid. I even check to see that th metal was connecting and it is. Now is there another wire that controls the windows that im not seeing. Or is there a fuse or somethin else that could be loose? im tired of having to drive around in 85 degree weather with my windows up and leaving it in the driveway with the windows down at night.
Old Sep 15, 2004 | 05:23 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
There is a pink (sometimes orange) wire that runs from the WDO circuit breaker (metal 35 AMP) on the fuse block to junction block C238 located under the dash behind the left kick panel. There is a pink wire that runs from there and splits off with a pink wire going to pin "D" of each power window switch.
Old Sep 16, 2004 | 08:10 AM
88firebird's Avatar
Car: 89 GTA (88 Firebird V6 to V8 conversion RIP)
Transmission: 5 spd
I had a similar problem with my car... in my case, it turned out to be a bad ignition switch... fiddled with the key in the ignition and it would start working again... on my car, when the windows stopped working, so did the vents! Replaced the ignition switch and windows work fine now.
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Sep 13, 2015 09:07 PM
stalkier
Aug 21, 2015 01:54 AM
