Dist wiring help (carb swap)
Old Sep 18, 2004 | 05:47 AM
AlabamaThunder's Avatar
Car: 1986 IROC-Z, 1990 RS
Engine: 383 Stroker TPI, 350 About To Go In
Transmission: 700R4 W/ Shift Kit And Stall, 700R4 W/ Shift Kit
I done a search and read the article on TBI to Carb but, I need help on wiring. Okay I get the part on wiring it the pink wire to the BATT and the White to the TACH on the cap, but where do the other ends/connecter go, since the tbi coil is no longer needed right?
Also where does the wires that use to go to the other female spot on the coil go now?
I'm very confused.
Thanks guys..I suck at wiring.
Old Sep 18, 2004 | 06:53 AM
Dave Y's Avatar
Car: 04 Xtreme Blazer
Engine: 4.3L V6
the only thing you need to hook up are the pink and wite wires in the connector from the harness, all the other are for the computer
Old Sep 18, 2004 | 02:40 PM
so i leave the other end of the pink and white wire hooked up to the TBI coil, and leave it all hooked in that way?
Old Sep 18, 2004 | 08:10 PM
Dave Y's Avatar
Engine: 4.3L V6
ok, remove the TBI distributor, remove the TBI coil, there is a 2 wire harness that goes between the two, you do not need this, there will be 2 connectors that went to the TBI dist.(at the bottom of the cap, in back), these, leavfe hanging, tape up, ect., they are not needed., then, there is one more connector that went to the TBI coil, it comes right out of the harness, this has a pink wire(might be pink with a black stripe) and a white wire(might have a stripe), these are the ones you need, pink to BATT and white to TACH
Old Sep 20, 2004 | 07:35 AM
Thanks.
I'm a dumbass
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
Infested
May 22, 2018 11:56 PM
midge54
Jan 29, 2017 07:00 PM
cstrobel65
Aug 15, 2015 10:19 AM
