I am stumped. car wont start.
Old Sep 21, 2004 | 07:54 PM
VETTESPEED's Avatar
Sorry, not a third gen, actually my wifes car a 95 camaro v6.
Put key in, turn to run position and get power to headlights, interior, what sounds like the fuel pump etc etc. After about 10 seconds abs light and security light (which is solid, not blinking) turn off.
Turn key forward, ABS light comes back on, but no start.
Car had an alarm aftermarket. I just finished pulling it out. All wires are as they should be. With alarm out, exact same symptoms.
Don't think it is VATS since security light goes off.
Cleaned plenty of corosion off of the positive terminal of the Neverstart.
Battery, alt, and starter are less than two weeks old.
If there is a starter relay I can not find it. Thanks!!
Mike
ww.vettespeed.com
Old Sep 22, 2004 | 11:13 AM
chevypower2002's Avatar
check the fusable link
Old Sep 29, 2004 | 07:22 AM
SaintedCorrupt's Avatar
Car: '85 TA
Engine: Carb'd 350, ported 416s
Transmission: retrofitted T5
Axle/Gears: 3.42 7.62" 10-bolt, locker
Also, the bendix sometimes gets stuck on a burr of metal when starters are new. Give the housing a tap or two with something hard and it might work.
When in doubt, hit it with a hammer.
theshackle
Mar 5, 2017 06:37 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
kyleb24
Aug 15, 2015 08:24 AM
86Base
Aug 8, 2015 01:34 PM
