power door lock actuators
Old Oct 6, 2004 | 06:12 AM
black84z28-4spd's Avatar
they dont wanna fully lock or unlock the doors...is my only option buying new ones?
how hard to change?
Old Oct 6, 2004 | 07:02 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Try cleaning the rods and hardware good.
Old Oct 6, 2004 | 07:06 AM
did that...seems they only wanna lock and lock halfway...i guess my only option is to try that relay/screw thing i saw after i posted or buy new actuators
Old Oct 6, 2004 | 07:09 AM
-ZERO-'s Avatar
Car: 86 IROC-Z (daily driver) 87 IROC-Z (under construction)
Engine: 305 H.O.
Over time these things wear out. If you do have to change them out, there not too bad. you have to drill out the rivets that are holding them in and either buy nuts, bolts and lock washers to put everything back together or rivet those things back in . but thats only if you have the tool to do it. ( you can get something like that at a place that sells tools, there not that expensive depending on what you get )
Old Oct 6, 2004 | 07:12 AM
thats the thing...i took the door panel apart and looked at them and lubed them up with white grease and to no avail...the rods and linkage are clean
even tried working it a few times...i wanna be able to use my keyless entry for the winter...wisconsin has some cold *** days and washing the car all the time the locks may freeze up...
Old Oct 6, 2004 | 07:33 AM
-ZERO-'s Avatar
Engine: 305 H.O.
sounds like you may just have to replace them. check out www.autoloc.com
Old Oct 6, 2004 | 07:35 AM
thanks
Old Oct 6, 2004 | 08:44 AM
little P's Avatar
Car: 89 Formula
Engine: 350ci, tbi
My lock on the driver side sticks too. If i push it no less that 5 times and in a morse code fashion it will finally lock.
Old Oct 6, 2004 | 01:06 PM
USA_Rally's Avatar
Car: 92 Rally
My passenger side does the same thing. Grrrrr, all the lil things eating me alive!!! lol
Old Oct 6, 2004 | 09:55 PM
Mr.W's Avatar
Car: 91 RS
Engine: 305 TBI
Transmission: Stock auto
Ive been having this problem too. will I need a new actuator? or just some greasing up? if it's the actuators, is this the right product? http://www.autoloc.com/detail.lasso?itemid=gt2000
Old Oct 7, 2004 | 04:28 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I had the same problem. I'd have to press the buttons a few times to get them to move all the way.
I sprayed lithium grease all over the linkages and started to move the rod back and forth quite a few times and now they work like brand new.
Old Oct 7, 2004 | 06:38 PM
redbird_400's Avatar
Car: 89 Formula Firebird
Engine: 305 - Demon 525
Everyone will get this problem! lol I have it.. what sux is that I installed an alarm system with keyless entry right? so I go to arm the car and it wont lock the door all the way! I have to manually lock them lol such a krock... but it unlocks them just fine lol. Tried to greese them but no go so.. ya know what? I'm not going to trust these old pos door locks. Because that one time where you press the button, you think its locked but some theif finds out differently THEN! your in some deep shat. So If they dont lock right, greese and cleaning doesnt work or doesnt give you a 100% sure feeling then REPLACE! Before you have to replace some stolen equipment from some car hopper....
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
neekolzun
Aug 24, 2015 04:59 PM
