LT1 Engine dies sometimes abruptly! Please help!
Old Oct 11, 2004 | 01:36 AM
firuzrasul's Avatar
The problem, my engine dies sometimes abruptly, it dies after 1 week sometimes after 5 minutes. The LT1 (´96) installed in my Cobra Kit dies suddenly after different operation times and temperatures.
Things I checked and replaced:
- Engine ground is perfect
- Battery is o.k., voltage on system is allways 12V
- Ignition Module is replaced
- Opti is replaced
- Coil is replaced
- No codes are indicated ever
- Fuel pump runs after switching on the ignition
So, I checked the ignition wireless with an voltmeter and find following problem.
From all wires of my ignition module, I have only one brown wire witch goes direct from the ignition module to the ignition coil. I measured on this wire normal 12,8 volt! When my engine died, I measured permanent about 4 or 5 volt!!! ;-(
After 10 seconds or after 30 secons, the voltage go on 12,8 volt and I can start my engine!!!
The same on an white wire on the ignition coil. This wire is for my engine revolution I think!
Funnily enough, I have a ECM from 93 and an LT1 engine from 96!!! My ECM works with map and maf!!! Is this possible Perhaps, it´s normal in a Cobra-Kit!!!
Please Heeeeelp and sorry for my bad English!!!
Cheers from Germany
Andy
Old Oct 12, 2004 | 06:39 AM
firuzrasul's Avatar
now you see the plan!
(8) and (9) is chrashed on 4 volt!
(6) and Ground of my car are the same!
(11) + (5) are ok!
and now?
Attached Thumbnails LT1 Engine dies sometimes abruptly! Please help!-lt1neu.jpg
Old Oct 13, 2004 | 09:02 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Are you positive that you have a 93 ECM?
eightsixseven
Dec 16, 2024 01:50 PM
midge54
Dec 27, 2019 04:14 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
