DS power door lock not working
Old Oct 17, 2004 | 09:20 AM
82CamaroZ28's Avatar
Car: 1982 Camaro Z28
Engine: Self-built 350
Transmission: Pro-Built 700r4 w/2800 Vigilante
Axle/Gears: Eaton 3.73 w/Moser axles
Here's the deal. I press the lock or unlock buttons in my car and now only the pass. side door locks and unlocks. Nothing is happening on the drivers side. Any ideas what this could be or where I should start looking? Thanks.
Old Oct 17, 2004 | 11:43 AM
Looking at the wiring diagram. It appears that the same relay activates the door lock actuators on both doors. Can anyone verify this?
And if so, that must mean that it is the door lock actuator that is bad, correct?
Old Oct 17, 2004 | 08:56 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Yes there is only one relay and it operates both door locks. Have you pulled the door panel off and looked at the connection for the driver side actuator? Have you had the driver side door panel off doing anything. Also check the wiring at the switches on the doors to see if one wire might be broken.
Old Oct 18, 2004 | 06:08 AM
No, I havent had the door panel off in about 2 yrs. It happened overnight. I have remote door locks and an alarm. I tried opening the doors with the remote and the drivers side didnt do anything and it was still locked, meaning that something happened after the alarm locked the door after the last time I closed it.
I will pull the door panel to inspect things as soon as I get a chance, but the switches on both doors still lock/unlock the pass. side door.
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
