wiper motor
Old Oct 17, 2004 | 07:53 PM
cyipher's Avatar
Car: 1984 Pontiac Trans Am
Engine: 305 SBC
Transmission: Automatic
wiper motor
Ok trickster and friends, i got one for you my window wiper motor will come on and have a high and low speed, but will not time delay, or shut off when you shut the wipers off, any clue on what would cause this
Old Oct 18, 2004 | 07:18 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
This sounds like the problem I had with my S15, the wipers are probably similar. For the truck it was bad solder connection on the PCB inside the wiper itself. It's an easy fix if you or a friend can solder. Check the connections at the harness jack and motor connector and check for and open trace at the relay. You'll see what I'm talking about when you open it up.
Frozer!!!
Jan 19, 2024 04:55 PM
siberian3rdgen
Interior Parts Wanted
Aug 31, 2015 09:37 PM
Randomtask2
Aug 26, 2015 03:34 PM
eddie jr
Aug 25, 2015 06:52 PM
slade5612
Aug 11, 2015 07:19 PM
