Trimming away excess wiring harness
Old Oct 21, 2004 | 07:23 PM
FLTraumaRN's Avatar
Car: 1988 Z28
Engine: 357 ci 472 hp at RWs
I am wanting to cut away all the excess wiring harness of my 1988 Z28. I don't need all the sensors nor do I need the excess ECM wires can any help me ?
FLTraumaRN911@aol.com
Old Oct 21, 2004 | 09:16 PM
Blown87's Avatar
Car: 87 Z-28
Engine: 383 HSR w/supercharger, AFR heads
Transmission: 700r4 w/2500 stall
Axle/Gears: 3:73
A Dopamine drip at 10-20 mcg/kg/min should give you the Alfa response you're looking for.
P.S.- sorry I can't help with your question, but welcome aboard!
Old Oct 23, 2004 | 07:08 PM
hookedon3gen's Avatar
Car: 88 camaro
Engine: 383 carbed
I have made the same transfer, only mine went from a 2.8 mfi to a 305 2bbl. and now a 5.7 tbi. Is your engine carb or tbi? That's the first thing. If you went carb. well you can start by id-ing the ground wires you do not want to cut them out. your ecm harness runs over towards the ac box and down the fender well. you can get to your harness clamp by removing the panel behind on the rear of the wheel well. Remove the pasg, side kick plate and you should see the clamp. Of course unplug your harness which is behind the dash on the same side, it's held in a upward position by a couple of 7mm screws i think. after that you will be able to pull the harness out and on to the fire wall. At this point you have to find your wires for your lights and alll the things youll need to keep running. I have no idea as to how your setup engine wise, but you can get a chiltons manuel and Id your wires. This is not easy if you are running fuel injection, cause your needs for elec. system are greater, but carb. you should not have to much of a problem...This site maybe a help....
www.geocities.com/vtcamaro/Wire-Diagrams.html
Old Oct 26, 2004 | 11:28 PM
stenseltizm's Avatar
Car: 89 RS
Engine: 400 sb
Hey I converted from a 89 rs 2.8 to a 400 sb, and i've been in the process of eleminating my excess wires too. my question, are any of the wires that run into the body connector on the passenger side needed for anything else but ecu? I'm trying to keep factory gauges and all that jazz. And anyone know how to re-do the factory tach to work with a v8? I was told it takes a new resistor added somewhere.
Old Oct 26, 2004 | 11:48 PM
Blade3001's Avatar
From my experience, only the reverse lights (to T5) run through the pass side. All sensors for gauges come through the drivers side bulkhead.
But I have a canadian LG4 that came stock with no computer or air pump and has non-computer carb and dist. Keep that in mind.
EDIT: also I have a mech speedo, I speculate that the electronic speedo has to go to the VSS which I might have seen on on the pass side on other cars. anyhow, just check the wires that go to the tranny first.
Old Oct 26, 2004 | 11:55 PM
Car: 89 RS
Engine: 400 sb
thanks for replying so fast, i have the car running i just had to rewire the last person's mistakes and figured i'd get rid of the excess while i was at it. sorry to jack the original thread
Old Oct 26, 2004 | 11:58 PM
Blade3001's Avatar
no prob, I think what id said will be helpful to the original poster.
I know about past owners mistakes. I found five non-stock relays wired to the headlight switch. there was no problem with them there and no problem without......
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
TheJoeY88
Dec 31, 2016 07:30 PM
stalkier
Dec 6, 2015 11:25 PM
g.l.mos
Aug 22, 2015 12:02 AM
stalkier
Aug 21, 2015 01:54 AM
