Do I need a resistor for this?
Old Oct 22, 2004 | 04:27 AM
jconrad's Avatar
Car: 89 Firebird
Engine: L05 350 TBI
Transmission: 700r4-slippin' on it's last leg
Okay, I have finally gotten a switch so that I can hook up my manual fan switch. It is a fog light switch from a T/A. My car is a base model, but it has the punch-out (actually unbolts) right under the headlight switch. I have the ground hooked up, the grey for illumination, and the green from the relay to turn the fan on. I am not sure which (if any) resistor I should use on the +12v red/black wire coming from the relay. It will turn on the indicator light when the fan is "on". This is the same wire that runs from relay to the fan motor, to supply it's power.
Old Oct 22, 2004 | 07:49 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I don't understand why you think you need a resistor. Is the bulb something less than a 12 volt bulb?
Old Oct 22, 2004 | 10:43 AM
jconrad's Avatar
Car: 89 Firebird
Engine: L05 350 TBI
not totally sure on that, and I have finally aquired this switch after months of looking. so i definetely do not want to burn it up, ya know?
The power wire from the relay is alot thicker gauge than all the rest, so I just want to be sure.
Old Oct 23, 2004 | 03:53 PM
jconrad's Avatar
Car: 89 Firebird
Engine: L05 350 TBI
Okay, I've got an update on my setup on this wiring. In the picture at the top of the page, there is a center plug that I wasn't sure what to do with. That plug needs to be grounded also, in order for the switch to work properly. I don't know why, but through trial and error, I figured that out.
Still haven't had any luck with wiring the indicator light. I think the bulb might be blown out. I see that the "OFF" switch does not illuminate like the "ON" switch. Guess I should have just bought a new one. Gotta love used electrical parts...
Elephantismo
Feb 13, 2019 12:51 AM
Eric2ndGen
Nov 5, 2015 01:51 PM
studebaker60
Sep 7, 2015 12:36 PM
greenyone
Aug 29, 2015 11:08 AM
Armored91Camaro
Aug 25, 2015 12:01 PM
