turn signal and hazard fuses blowing
Old Oct 23, 2004 | 05:22 PM
Diggler86's Avatar
Car: 86 TA
Transmission: 700R4 - 2200 stall
Axle/Gears: 3.42 posi
both turn signal and hazards are blowing their fuses. does this mean it definately means its in the wiring/bulbs and not the steering column? (their was a little smoke there when the turns blow).
the parking lights work fine.
it just rained a lot and im guessing some water maybe got in the rear lights. the front lights i checked are dry and clean. but last time i checked the rears they were pretty gunked up. how/what do i clean that crap out of the socket with? is there supposed to be some grease in there?
is there and easy way to check the wiring for a ground?
thanks
Old Oct 25, 2004 | 12:11 PM
Diggler86's Avatar
Car: 86 TA
ok, so i took all the light out of the rear, cleaned the sockets best i could. they are dry but do have some of that tan goop in there. all the bulbs worked.
i tested the hazards and turns while it was parked there by turning the key to 'on' position. they all worked fine.. so i was like aha! i finally got it.
then i went for a drive and a few minutes later POP goes the fuse. is this b/c the volts are higher 14~15 than when cars not running 10~11??
now im confused. should i throw a 30A in there?
Old Sep 10, 2014 | 06:09 PM
cerhart's Avatar
Car: berlinetta
Engine: Lt1
Transmission: t56
Re: turn signal and hazard fuses blowing
I'm currently having this same problem, changed all my bulbs made sure grounds are good and changed my turn signal switch all with no luck I'll let u know if I come up with a fix
Old Sep 10, 2014 | 06:10 PM
cerhart's Avatar
Car: berlinetta
Engine: Lt1
Transmission: t56
scratch that old post did u find a fix or someone HELP
Old Sep 10, 2014 | 08:39 PM
89blackformula's Avatar
Car: 89 firebird
Engine: LB9
My formula did this also.
On mine it was the turn signal flasher..the plastic cracked off and insides shorted to ground on the metal under the dash.
The problem was intermittent as the bumps going down the road moved the damn thing...so some times it worked other times it blew,
Took me a few try's to track it down.
Hope this helps
Ghettobird52
Jul 5, 2024 11:18 PM
Fronzizzle
Mar 18, 2019 08:29 PM
dibella989
Sep 1, 2015 04:12 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
