starting problems
Old Oct 26, 2004 | 08:53 PM
boomaceboom's Avatar
Car: 1984 Camaro Z28
Engine: 305 V8 High Output
Transmission: 700-R4
starting problems
i drove my car home from the shop on friday without the alternator hooked up. the shop said it was bad and needed to be replaced. today (tuesday) i bought a new alternator, installed it, and tried to start the car. No luck. No electricity. On the passenger's side fender there was a wire, with one end unconnected. There was a place on the negative terminal of the battery where a uncovered wire lay. I hooked this wire up to the wire on the inside fender, and the electric fan started turning. I then proceeded to my cockpit, and turned the key over. sparks flew from the place that i had just connected, but the car didnt start. What did I do? What will I have to replace, What do i have to hook up? Please help, i have no idea what happened and I need this car to run.
Old Oct 26, 2004 | 09:42 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
What color was this wire? BTW, driving with the alternator disconnected is an excellent method of trashing a perfectly good battery in a very short period of time.
Old Oct 26, 2004 | 10:21 PM
What if my battery is charged? what did i blow, and what will i have to replace?
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
92camaroJoe
Aug 13, 2015 06:07 AM
mustangman65_79
Aug 8, 2015 12:07 PM
