frequency doublers?
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
frequency doublers?
by anychance, does anyone here know of a IC or circuit i can use as a frequency doubler?
im trying to get one to convert the tach signal of a LS1 (2 pulses per rev, like a 4 cyl...) to work with V8 tachs ( 4 pulses per rev)
with a bottom reading of about 500 and a redline of 9k thats a input operating range of .06 - 1.08mhz and double that on the output.
input voltage is in the 3v-6v range, output the same.
i havent had any luck looking for ICs online i could use, and all the places i found except digikey only sell to companys in bulk.
and please dont suggest i just buy one of the prepackaged "tach converters" or somthing similar.. i know they're out there, but id rather make one, and if it works, make a couple more so we can all have CHEAP ones instead of paying $40-$100 for nothing more then a simple circuit.
Car: check
Engine: check
Transmission: check
An XOR gate, a resistor and a capacitor:
At 9K RPM the frequency will be 600 Hz. At 500 RPM the frequency will be 33.3 Hz. This is for a V8 and a tach pulse per plug firing.
Haven't the foggiest idea how this relates to DIY PROM. . . figure that the electronics board may be best.
RBob.
Code:
in -----+--------------| |
| | XOR |-------out
gnd Haven't the foggiest idea how this relates to DIY PROM. . . figure that the electronics board may be best.
RBob.
Car: 91 Camaro Vert
Code:
| | XOR |-------out
gnd what values would i need for the components?
the single im getting is a pure 5v square wave 2 pulses per rev, generated by the PCM.
RBob.
RBob.
the electronics board is "how do i wire up my headlights?". the people who i want to see this thread, arnt in there.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: frequency doublers?
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
www.mouser.com has almost everything.
99Hawk120
May 15, 2002 12:44 PM
Jon88GTA
Mar 23, 2002 05:52 AM
