Want to disconnect Power Antenna in up position, which wires to cut?
Car: 82 Camaro Pace Car & 1989 IROC
Engine: LG4. & 350 TPI
Transmission: 200C
So my power antenna is giving me problems ... it won't retract down properly. Up is usually a struggle too.
If I pull out the radio, which wire do I cut to keep it in the up position?
I tried the pink, but it retracts anyways.
Help ... !
Pacer
Help ... !
Pacer
Car: 89 Camaro
Engine: 355
Transmission: Coan rebuilt TH700R-4
power wire
Instead of cutting a wire behind the radio see if you can find the power wire right at the antenna itself and unplug it.
Transmission: 200C
Thx.
Well I found the solution.
Remove the panel above the passenger foot well and disconnect the 3 wire harness that goes from the radio to the antenna.
You need to look for it as it's kinda hidden beneath the dash.
This harness plugs in at the rightmost side going towards the antenna underneath. Just have to remember to have the antenna up and radion ON as you do this.
Went to a stereo shop and had it done in 2 minutes flat.
Pacer
Pacer
Ghettobird52
Jul 5, 2024 11:18 PM
db057
Aug 11, 2015 10:11 PM
