power door locks
Old Nov 8, 2004 | 09:39 AM
VroomVroom87Z28's Avatar
Car: 87 Z-28
Engine: 305 ci. LB9
power door locks
Just boughtt this car and am in the process of fixin it up and gettin it on the road. One of my problems is the door locks, they don't work, not like they should anyway. I'm changing the interior color so everything's ripped out and easy to get to. Here's the problem, the solenoids aren't moving the arms all the way up or down, it's like they've gone weak or something. I cleaned them off and sprayed blaster on all the moving parts and that helped a little, if I really pushed on the lock button they'd go, but they wouldn't unlock all the way. The problem is the same on both doors. Have I got an electrical problem or do I just need new solenoids? If so, where can I find them, I haven't seen them in any of the reputable parts dealers....or maybe it's just a NAPA part. Any help would be much appreciated.
Old Nov 8, 2004 | 04:28 PM
LO3Jeff's Avatar
Car: 1992 Camaro RS
Engine: (LO3) 305 TBI
Transmission: 4spd
Can you here the solenoid Closing? You should here a click and the motor should try and move the lock. Most likely a bad motor.
Old Nov 8, 2004 | 04:45 PM
305q_ta86's Avatar
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
Ah my 87 has the same problem. It gets worse when it's cold. Same as the windows. Bad solenoid, at least that's my problem. I suspect yours is too. I wouldnt trust the junkyard ones to be any better, but I know install shops can rig up new solenoids as a part of the keyless entry package, and it should be reasonably cheap...
Old Nov 8, 2004 | 11:08 PM
Silver_IROC_87's Avatar
i wouldnt bother until its on the road....cuz i have the same problem with my 86 so i was like f- that ill worry about it when i can drive it
Old Nov 10, 2004 | 12:46 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Check voltage at solenoid when powered. Not unusual for the door switch to corrode. Lube the little pivot point on the right angle bellcrank job really good. Spray the heck out of the latch assembly. Get solenoids on Ebay, aftermarket, pretty cheap and they are easy to rig up, real powerful too.
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
neekolzun
Aug 24, 2015 04:59 PM
