Dash Board Trouble
Old Nov 14, 2004 | 03:03 PM
Formula94's Avatar
Car: '88 Firebird, '91 T/A, '94 Formula
Engine: 305ci TBI, 350ci TPI & 383ci LT1
Transmission: T-5, 700R4 & 4L60E
Dash Board Trouble
When i turn on the headlights in my firebird the lights for the gauges do not come on and the radio display turns off, the gauges do work, the other lights on the dash work such as the parking brake light and the seat blet light, my friend is having the smae problem with his IROC so i thought this may be a known problem, if anyone has any clue how to remedy this problem i would greatly appreciate it. Thanks
Old Nov 14, 2004 | 09:12 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Have you checked to see if any of your exterior lights are out when you turn the headlights on? Also have you checked the "TAIL" & "INST LMP" fuses really good?
Old Nov 15, 2004 | 10:18 AM
Formula94's Avatar
yea it turned out to be the IST LMP fuse, thanks for your help
Old Nov 15, 2004 | 10:23 PM
91RSHawaii's Avatar
Car: 1999 30th Anniversary Pontiac T/A
I have the same problem, could it be anything other than the fuse causing this? as all my exterior lights work
Old Nov 15, 2004 | 10:29 PM
84camz28's Avatar
Car: 1988 IROC-Z/1996 DODGE RAM 1500
Engine: 350 L98 TPI/360 v8
Transmission: 700r4/46RE 4x4
Axle/Gears: 4th gen 3.42 10 Bolt Posi/3.90 posi
you might have a bad dimmer switch in the headlight switch. i would replace it.
F.I. 57 Belair
Aug 23, 2021 01:09 AM
Elephantismo
Feb 13, 2019 12:51 AM
MantyZ28
Nov 8, 2015 06:54 PM
BWilcox
Sep 20, 2015 12:19 PM
ChristinaMarie
Sep 11, 2015 06:28 PM
