hatch problem
Old Nov 29, 2004 | 12:35 AM
Greygoat's Avatar
hatch problem
i have an 89 firebird and the rear hatch gizmo will not pull it down anymore. It used to work but now it does not do anything. when i press the button to open it the brake light indicator in the gauges lights up. any answers will be helpful.
thanks
Old Nov 29, 2004 | 01:56 PM
camarodragon's Avatar
Car: 86' Camaro Z28???? could be any thing it orginally had a 5. slow now its dressed in RS attire.
Engine: 350 carbed
Transmission: 700 R4
hey mine was originally not working..first i would suggest checking the to se if the wiring from the switch is all conected. Then take off the hatch gizmo thing cover and see if everything is connected. Then i would go into the fuse thing under the steering column and make sure its all plkuged into LID... if ur lights inside r not working then u will have a problem with the hatch as well. If all that fails ur motor might be broken. As i said mine was originally not working and i have an 86 RS, then i got it all coneected and it worked. then since the motor was so old and i had no shocks on my hatch at the time the motor broke trying to lift it...lol...**** happens huh. just play with all the possibilities besides if it dont work its not that big of a deal just do it manually to get stuff out the back.
Old Nov 29, 2004 | 08:29 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Contact Lonsal at Top Down Solutions (TDS) located at the top of the page.
Street Lethal
Apr 30, 2019 12:14 PM
hydrolic144
Sep 8, 2015 06:55 PM
2012sergen11
Interior Parts Wanted
Sep 7, 2015 11:37 AM
neekolzun
Aug 24, 2015 04:59 PM
madsv1000
Aug 20, 2015 06:45 AM
